Author Topic: Tire valve stem sizes?  (Read 2003 times)
« on: March 01, 2019, 12:38:20 PM »
Hi all!
I am in the process of getting some car preps and among them are tire valve stems. But I am amiss to sizes.
This link was not that much helpful.
https://resources.tireamerica.com/research/tire-valve-stem-types
TS413, TS415 or what?. 453 or. 625 ones?
We are talking 14 inch passenger car steel rims.
Also, would you buy a plastic puller tool as a cheap,  one use option?
Thanks,  GM
Re: Tire valve stem sizes?
« Reply #1 on: March 02, 2019, 01:23:51 PM »
Not sure on the newer cars about stem sizes. The older cars were all the same, except for the length of stem. Hubcaps required a longer stem.
As far as the insertion tool, buy a good metal one like the tire shops use.
« Reply #2 on: March 08, 2019, 01:09:44 AM »
I am bumping it on top cos there is no other way to find out the diameter being either .453 or .625
« Reply #3 on: March 08, 2019, 05:45:17 AM »
If I am understanding the tables in your link the TS413/415 stems are typically for passenger cars and a max cold inflation pressure of 65 psi. This would be the .453 dia. valve stems. The choice between the 413 and 415 is a matter of effective length. 1.25 inches vs. 1.75 inches. Seems to me if the vehicle had full wheel covers the longer stem would likely be needed. Small of no hubcaps a shorter stem might be OK.
« Reply #4 on: March 08, 2019, 11:17:21 AM »
the length i can gauge and measure and getting a .25 inch longer by mistake is no hassle in the style of hub caps the rims wear. But the rim opening for the valve I canno, since some spare ones have tires on them.
Thanks for the guidance.
« Reply #5 on: March 08, 2019, 04:35:04 PM »
Greekman I strongly suspect that passenger car wheels all have the smaller holes for the stem unless of course they are for the high pressure tires. As you probably know you can read the normal cold and probably max inflation pressures on the side of the tire. That brings us to the compact spare tires which the ones I've seen specify an inflation pressure of around 70 psi I think. Does this take the larger diameter stem. I can't answer that except to say refer to those tables in your link or ask a car dealer maintenance shop or a tire shop.
« Reply #6 on: March 09, 2019, 03:24:22 PM »
no need...I have a regular spare :)  and my tires are 30-32 psi
