The Fan Dipole is often way over-built with todays automatic antenna tuners (and manual tuner ,for that matter) a multi-band antenna need not look like a NASA radio installation. All you need to build a 6 through 40 meter antenna is 110 feet or so of wire ,insulators (made from PVC pipe ) and a 1 to 1 BALUN / Feed Point where it all comes together...Plus a bit of rope (black 550 para cord is my choice).
The balun is a transformer that helps to keep your radio from interfering with other electronics and you will find it worth the $20 to $30 you spend. It also handles the two wire antennas and coax connections. The common feed point should be up 20 feet or so ,hung from a pole,tree or tower,or even rooftop. with the two antennas sloping down to a lower (but still above head level) support at the ends with a bit of rope and insulators to do the job. My antenna has slim 10 ft sticks of conduit stuck in the cyclone fence for it's end supports though I do have a tower finally...the original middle support was an 18 foot aluminum pool cleaner/skimmer pole and I still have it.
A picture is worth a few words here:
and with these TWO dipoles ,I work 80 ,60,40,30,20,17,15,12,10,(whew!) and 6 meters with only a 3 to one tuner in my radio. Though I suggest a better capable range tuner like most any LDG tuner and a 4 to 1 Balun for your widest range of antenna use. My antenna was made from an extension cord that was put to the curb after a neighbors hedge trimmer incident and some PVC with the only real cost being the Balun that cost only $16.95 back in the day.
NOTE that I chose 20 and 40 meters as they are my favorite bands and I see little need to add other wires cut for other bands that my tuner can already deal with...what I give up in efficiency I make up for in ease of install and operating time. If you feel the need to TUNE each band buy cutting(and this can help) PLEASE cut the lowest frequency first (longest wire pair) and remember that there is a bit of inter-action between the wires ,so cut carefully...if you must mess with it.
Happy Hamming!
