It's nice but for 12 bucks you can get a car battery charger solar panel from surplus shed
http://www.surplusshed.com/pages/item/r3265p.htmlYou'd have to fabricate your own connection wires and adapters but given the one you posted puts out far less power you'd still be better off money-wise. (The surplus panel is 12v / 1watt - specs aren't given on the other panel but based on the devices listed I'd guess it's good for 6v and 1/2 watt).
Surplus shed also sells "junk" panels very cheap (junk as in loose, 4 inch arrays, not junk as in quality). Wiring the auto charger panels in parallel you could assemble a panel large enough to power a laptop or charge batteries and an inverter for A/C appliances with 5-10 of these.
The "real" panels built using modern, efficient methods run about 500 bucks or more for a panel capable of 200 watts. A basic solar backup system capable of running a fridge a few hours a day will cost you around 1200 for the panel, batteries, controller and inverter. I'm always looking for a cheaper way to build one of these if anyone has them.
Hopefully some of the new solar panel technology will become available, like the hyper efficient panels based on the same type used by satellites and the space station but much more affordable or the "printable" ones currently in testing. So far my research shows building a solar concentrator with steam or Stirling powered generator or a biofuel / methane fuel cell will give you more power for less money. The CHP systems which use thermal energy for heating and hot water to also generate power are probably the best but they are expensive to buy and require a fuel source to burn.
