Author Topic: DIY Ferro rod  (Read 11981 times)
Offline Nate
  • Rookie Registered Nurse
DIY Ferro rod
« on: March 03, 2011, 12:27:15 PM »
I have been wanting to make my own ferro rod from a blank.  What type of adhesive is best to attach a wood, bone, antler or plastic handle on a ferro rod?
Offline JerseyVince
Re: DIY Ferro rod
« Reply #1 on: March 03, 2011, 12:31:35 PM »
Permabond two-part epoxy can find it at any home improvement/autoparts/walmart store
Re: DIY Ferro rod
« Reply #2 on: March 03, 2011, 06:03:21 PM »
I'd cut a couple of small lateral grooves in the end of the ferro rod that you're applying the handle to just to give the epoxy a little something extra to grab onto.
Offline mxitman
    • Heezy
Re: DIY Ferro rod
« Reply #3 on: March 03, 2011, 07:24:13 PM »
Nate, I use a 2 part epoxy as well... I usually make a few at a time since you will be mixing them up anyway. Here is an example of my SKC setup that I sell.
Offline Huntinbull
  • New TSP Forum member. MOLON LABE
Re: DIY Ferro rod
« Reply #4 on: June 14, 2011, 06:30:49 PM »
I have used pl400 (liquid nails) since i have a tube loaded in a caulk gun generally all the time. Any epoxy should work. I cut a keyway or sliver into the rod lengthwise and on bigger items like a 3/8 ferro rod or a file handle, I may even put a groove around the rod at about half the depth of the hole in the handle material.
Offline d0j0w0
Re: DIY Ferro rod
« Reply #5 on: June 14, 2011, 09:15:37 PM »
J-B weld works well.  But, I'm not sure if it is the cheapest epoxy out there.
J-B weld would be a good item for a BOB.
Offline motionman2
Re: DIY Ferro rod
« Reply #6 on: July 29, 2012, 09:40:25 PM »
Hello everyone, I've been playing with this idea as well.....I saw someone was using fatwood as the handle material (just in case tinder is hard to come by).  Anyone have experience working with fatwood?
Re: DIY Ferro rod
« Reply #7 on: November 14, 2012, 09:48:17 PM »
I found this site for firesteel blanks: http://firesteel.com/
Offline travisonfire
Re: DIY Ferro rod
« Reply #8 on: October 23, 2013, 08:09:53 AM »
we use fatligher all the time, or fatwood.  I'm guessing its the same thing.  Its comes from the bottom of dead pine trees.  all the sap rests there in the roots.  Has an almost sweet smell.  Easy to light and burns hot and long.  Just chop a piece off about the size of a sharpie to carry with you.  When you need to use it just whittle some pieces from that.
Offline Trailboy
Re: DIY Ferro rod
« Reply #9 on: July 09, 2014, 09:25:39 AM »
This sounds like a dumb question, but did you make the Ferro rod yourself or buy a large sized rod? I have thought about using PVC pipe and a 2 part epoxy
Offline bcksknr
  • Child of the Cold War
Re: DIY Ferro rod
« Reply #10 on: July 09, 2014, 05:54:17 PM »
     I made some firerods by epoxying ferro rods into deer antler tips. They look really good.
