Author Topic: Kolbeson all kydex holster review - full review  (Read 3070 times)
Offline calicojack
« on: April 30, 2010, 04:06:16 AM »
Kolbeson Leatherworks Kydex IWB Holster
Article found at: UrbanTacticalGearReview.com
Article by: Eli Miller
I am going to just come out and say it. This is probably the most versatile kydex inside the waistband holster regarding placement that is currently on the market. The size, shape, and loop placement make this a 360 degree mountable holster. There are a few holster makers out there that have figured out the need for loops made to split around a belt loop, but their holsters are generally too wide horizontally to be placed in some positions on the body or any flat spot in general. Don’t get me wrong, I love the fact that holster makers are now taking into consideration that the body has curves, but again, it takes away from versatility when you are talking about placement. The wider the holster, the more curvature so to speak is needed to make it both comfortable and concealable. With Kolbeson’s  kydex IWB, it is only slightly wider than the dimensions of the gun itself with very little excess material, so no curve is needed to make it fit the body.
Let’s talk construction now. Kolbeson uses only 0.80 thickness kydex which is optimal for strength and comfort alike. It’s a single piece of kydex formed as a clamshell instead of two pieces mated by rivets which make the need for excess material on each side .The sleek, form fit shape adds to the rigidity of the holster also. This design greatly diminishes the chances of the holster cracking because there are less stress areas should a great amount of force be exerted directly on the holster in any situation.
Traditionally I have always worn my primary carry gun at about 3:30 to 4:30 on the body and a secondary on the ankle or in a pocket. With the temperature rising and my dress changing, I have been carrying more and more between 1 and 2 o’clock. Carrying here leaves ZERO print when I wear a t-shirt. Through various training courses, it has been beat into me the need to also have better support hand access to a gun or even my secondary be on the support side. With this, I think another handgun positioned at 11 o’clock is optimal. If you decide to carry anywhere from 10 to 2 on the body, you need a smaller, flat holster.  Some manufactures are placing an offset attachment as a means to secure them to the belt now. With loop placement on the Kolbeson IWB, an offset attachment is not needed at all for any postion you place it at. Put this holster where you want and you will not have a problem, it’s that simple.
The below picture shows what is concealed under the above untucked t-shirt.
The below picture shows the ability to split around belt loops should you prefer to carry that way.
Just to touch on it a bit, appendix or carry anywhere from 10-2 has some great benefits. Depending on your frame and build, it may or may not work for you though. I find it very easy to conceal while just wearing a t-shirt, I can better access my pistol from here while in a car with my seatbelt on if I had to than if it was further back, and I do not have to worry about bending over and my shirt coming up revealing the handle of a pistol. A lot of professionals will also argue that carry here is a big plus in grounded combative situations. As far as seated though and especially in a vehicle, I still prefer a pistol on the ankle, but when wearing shorts you might get some strange looks in public.
I haven’t just worn the holster; I have trained with it also. It was used for the duration of the OPS Surgical Speed Shooting course taught by Andy Stanford that I attended April 10-11. That class gave me the opportunity to get a couple hundred draws and reholsterings with it in a very short time. Josh has customer service and ease of operation at the front of his mind, he ships all of his holsters that have adjustable retention with the proper size Allen wrench to adjust them. Once I found the retention I wanted, I was good to go. The cut of the holster is just what is needed to get a full fighting grip on your pistol from the start. The sweat guard is just right and is not too large nor does it have sharp edges. All the exposed ends of the kydex are expertly sanded and blended leaving a very clean and snag free holster. Since the holster reviewed here was for a Glock, I will mention that it was molded with an extended slide release so it will work with a pistol that has a standard or extended release. The sight channel run evenly down the entire length of the holster and leaves a snag free draw every time. Being the craftsman that he is, Josh will not let a kydex holster out the door without something he is known for; leatherwork. The loops with pull the dot snaps are leather instead of the normal plastic or rubber which you typically see. It’s a nice change that adds durability as well as aesthetics to the finished product.</p>
The below picture shows just how the design of the holster allows you to draw every time with a fighting grip on the pistol.
I am more than pleased with all of the Kolbeson Leatherworks holsters I have at this time and look forward to all his new products as they come out. At this times, there are 2 IWB kydex holsters listed, a unlined version as reviewed here and a pig skin lined version. Josh prides himself with his warranty and customer service, and for good reason: he wants you to be happy with your purchases. To top it off, he offers military and law enforcement a whopping 15% off discount on his 100% custom made products which is something no one else matches that I know of.</p>
Contact information for Kolbeson Leatherworks is:
Josh Kolbeson
Kolbesonleatherworks.com
Kolbeson Leatherworks Facebook Page
josh@kolbesonleatherworks.com
Disclosure: I am not an employee, nor have I ever been an employee of Kolbeson Leatherworks. The item reviewed was gifted to me by Kolbeson Leatherworks for the purpose of a product test and evaluation. The items pictured and reviewed are my personal property. The opinions and views expressed in the posting are that of my own and are not influenced by any outside sources.
Re: Kolbeson all kydex holster review - full review
« Reply #1 on: April 30, 2010, 06:49:12 AM »
Very nice holster and great review.  Having just obtained my carry permit, i'm looking for IWB holsters and also experimenting with carry positions (Using the two el cheapo holsters I have.  This is great info.
I'm definitely leaning toward kydex holsters.  Being a little (ok 50lbs) overweight.  I tend to have issues with anything in the front or early sides.  The Kidney buster as I call it LOL carry so far is the most comfortable for 80% of my movement, but i'm discovering its a bit painful in some sitting positions.
Thanks for doing such a thorough review.
Offline RacinRob
  • I can be an ankle biter too!
« Reply #2 on: April 30, 2010, 08:10:23 AM »
I wish I liked GLocks becuase I would have the choice of any holster in the world... But I don't.  THey look nice but don't offer a holster for anything I own.
Offline calicojack
« Reply #3 on: April 30, 2010, 01:01:06 PM »
racinrob,
josh is currently in the process of getting more blue guns, so keep checking back. He's just released an OTW all kydex and is working towards making me a custom leather wrapped kydex for my g19 w/tlr-1 light.
Offline razor sharp
« Reply #4 on: April 30, 2010, 03:14:46 PM »
Hey doc, knowing your current  stature(no pun intended...ok, a little pun) have you considered a horizontal sob(small of back) holster. the cloths you wear and your shape would make it a comfortable option. i love kydex but the bare bones kydex iwb ive tried are no were near as comfortable as a good leather iwb. i own the serpa kydex holster for out of the pants carry and love it though. finding the right carry holster is like finding socks, a lot will fit but only a few will be comfy enugh for all day. good luck and glad you got your permit, im sure a lot of iowans will be getting theres soon, good job culver!
